kookykrispy
    Exhaust Manifold to Exhaust Pipe
    Number of posts : 1651
    Exhaust Manifold to Exhaust Pipe Empty Exhaust Manifold to Exhaust Pipe
    Post by Scott Thu Dec 02, 2010 8:47 pm
    I planned on piecing together my own exhaust system, but I got to looking at it tonight and it looks like it needs a doughnut gasket. I don't know if I can buy the connector pipe that will fit this. If I buy a connector made for an aftermarket header there won't be much gasket in there.
    Exhaust Manifold to Exhaust Pipe 129
    So I took a picture of the exhaust manifold from the old engine to see if it was beveled too. I don't remember a doughnut gasket coming off the old engine.
    Exhaust Manifold to Exhaust Pipe 221
    So here's a picture of the pipe I pulled with the old engine. Looking at the end it looks like it just slides up into beveled manifold.
    Exhaust Manifold to Exhaust Pipe 319
    So, to get to my question..
    Can I buy this end to make my own pipe, or do I have to take it to a muffler shop to get the right end?
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Exhaust Manifold to Exhaust Pipe Empty Re: Exhaust Manifold to Exhaust Pipe
    Post by kookykrispy Thu Dec 02, 2010 11:16 pm
    The donut gasket fits inside the pipe on one side and then inside the bevel on the manifold. You can buy that gasket at any parts store for probably under $5
    Post by donivan65 Fri Dec 03, 2010 12:26 am
    Both the flange and ball type are muffler shop made by squashing the end of the exhaust pipe,,,,,,the flange type uses a gasket,,,,,metal is better than the composite type,,,,,,,the ball type has the gasket kind of built into it,,,,,,,,
    Exhaust Manifold to Exhaust Pipe Metal_10
    sparky
    Number of posts : 195
    Post by sparky Fri Jun 10, 2011 7:00 pm
    Scott wrote:I planned on piecing together my own exhaust system, but I got to looking at it tonight and it looks like it needs a doughnut gasket. I don't know if I can buy the connector pipe that will fit this. If I buy a connector made for an aftermarket header there won't be much gasket in there.
    so what did you end up doing ? my van has that same decrepid looking exhaust bevel in the manifold and the pipe has that same welded on looking doughnut and I want to seal it up so the fumes wont get me wasted everytime I drive this thing, I have it all apart and am trying to get it back together nice and tight
    sparky
    Post by sparky Fri Jun 10, 2011 10:00 pm
    donivan65 wrote:Both the flange and ball type are muffler shop made by squashing the end of the exhaust pipe,,,,,,the flange type uses a gasket,,,,,metal is better than the composite type,,,,,,,the ball type has the gasket kind of built into it,,,,,,,,
    Is Scott's the flange type that would need a metal gasket ?
    Post by donivan65 Fri Jun 10, 2011 10:35 pm
    If the manifold has a tapered seat, the exhaust pipe needs to have a taper to seal,,,,,,,,some have a ball type built onto the end of the pipe, some are wedged shaped that require a wedge shaped gasket that goes between the exhaust pipe and manifold,,,,,,,,the engine moves when you accelerate,,,,,so there has to be some flexibility in the exhaust pipe and manifold connection,,,,,,,but put a gasket in there and see if it seals,,,,,,,if the gasket is not right, you will have a noticeable exhaust leak that will be noisy,,,,,,and you can put your hand up there and feel it if it is leaking,,,,,,,
    Post by donivan65 Fri Jun 10, 2011 10:49 pm
    Exhaust Manifold to Exhaust Pipe Repai140
    Post by Scott Sat Jun 11, 2011 8:08 am
    I ended up going down to a muffler shop and explaining what I was working with, and the size of the pipe. He took a piece of scrap pipe that had a 90 degree bend and flared the end like the left one in the picture Donivan posted.
    It's still an open pipe, but at least it's blowing down and out behind the driver's wheel.
    Post by Twinpilot001 Sat Jun 11, 2011 9:54 am
    Add =Anti- sieze to all exhaust studs & bolts=before installing the system- You will never regret it- Im talking the copper based stuff=napa sells it. easily removal if you ever need to.
    sparky
    Post by sparky Sun Jun 12, 2011 7:32 pm
    donivan65 wrote:Exhaust Manifold to Exhaust Pipe Repai140
    Mine is just like the one on the right, and the bevel in the exhaust manifold is REAL skanky where that pipe mounts, doesnt look like it could ever seal up there, should I have a muffler guy make me a new pipe and flare the end and use a gasket/donut like that one on the left ?
    Post by donivan65 Sun Jun 12, 2011 8:32 pm
    So what is wrong with the taper in the manifold?
    Exhaust Manifold to Exhaust Pipe Repai146
    sparky
    Post by sparky Sun Jun 12, 2011 9:51 pm
    the taper in mine is pretty ugly... corroded and rusty, I am gonna scrape it and hit it with a wire wheel tomorrow and hope it cleans up...Is there supposed to be a gasket on the one on the right ?
    Post by donivan65 Sun Jun 12, 2011 10:41 pm
    The taper needs to be smooth to seal,,,,,,ain't no law saying you can't put a gasket on any exhaust pipe,,,,,,,so grab one of those $1.99 composite exhaust gaskets, #8194 at Autozone and file one side down if it won't fit right,,,,,,,
    sparky
    Post by sparky Sun Jun 12, 2011 11:06 pm
    uh huh.....got it THANX!!
    Number of posts : 1046
    Post by VANagain Thu Jun 16, 2011 1:23 am
    The pipe on the right in Don's photo looks to me like it was made to not need a gasket. Kind of like how double flared brake line works. When you tighten it up, the flare in the tubing gets forced to conform to the mating shape. It works for brake lines but they don't get jerked around as much as the exhaust pipe. I must say, though, I like how the other pipe extends up into the manifold. Seems like that would help stop leaks.
    I like the composite gasket ring. It's softer than metal so I think it will fill in any little gaps, like on a rusty, skanky exhaust manifold. Don got me the same pipe as his (on the left). I brought it to a muffler shop to get the right gasket ring and I saw that the angle of the pipe's flare didn't match the ring. The guy went to his bending machine, which also had a flaring thing, and just bumped my pipe lightly a couple times, which flared it out to be a perfect match for the ring.
    Post by Scott Thu Jun 16, 2011 5:07 am
    The pipe that was connected to the engine I pulled was just like the one on the right too. I was told that my current manifold was pulled from an International Harvester 250 or 292. This manifold dumps to a 2.5" pipe, that's why it was swapped out.
      Current date/time is Sun Apr 28, 2024 10:21 am
