    Exhaust pipe exit location
    rustytoolss
    rustytoolss
    Number of posts : 624
    Exhaust pipe exit location Empty Exhaust pipe exit location
    Post by rustytoolss Thu Nov 13, 2014 6:53 pm
    I'm re asking a question that I asked awhile back. Well sort of. I'm going to replace the mufflers on my 64 pickup. I was going to run full tailpipes with exits Behind the rear tires. But lately have been thinking of just having short tailpipe exit just in Front of the rear tires. Would exiting in Front of the rear tires create any unwanted exhaust fumes in the cab ?? And how much louder do you think it would in the front, as compared to the rear ? ?
    It sure will be cheaper, and easier to use short side exits.
    Exhaust pipe exit location Empty Re: Exhaust pipe exit location
    Post by Guest Fri Nov 14, 2014 6:22 am
    rustytoolss wrote:I'm re asking a question that I asked awhile back. Well sort of.  I'm going to replace the mufflers on my 64 pickup. I was going to run full tailpipes with exits Behind the rear tires. But lately have been thinking of just having short tailpipe exit just in Front of the rear tires. Would exiting in Front of the rear tires create any unwanted exhaust fumes in the cab ?? No, none, the factory did it that way for a reason, did you watch the O-haulin A100 and pay attention to what they said about the exhaust with the gas tank? And how much louder do you think it would in the front, as compared to the rear ? ?[/i] With a decent or perfoemance muffler, very little to none.[/i]
    rustytoolss
    rustytoolss
    Post by rustytoolss Fri Nov 14, 2014 11:42 am
    So from what you said, the tailpipe came from the factory with it exiting in Front of the rear tire. Were all A100s that way, or just the pickups ?
    Post by Guest Sat Nov 15, 2014 9:16 am
    Both!
    Post by Twinpilot001 Sat Nov 15, 2014 10:06 am
    Pickups could exit the tailpipe before the rear wheels-ONLY!1 Vans only after the rear wheels- was a safety thing required! Must be aft of any passenger compartment!
    Post by Guest Sat Nov 15, 2014 10:17 am
    Not true pilot!
      Current date/time is Fri Apr 19, 2024 3:12 am
