After much thought I've decided to bite the bullet and get the Ron Francis harness for my '64 econo.
http://www.ronfrancis.com/prodinfo.asp?number=XP-67
I'm trying to order this but have run into some questions that perhaps some of you may know the answer to.
It asks me for what kind of alternator I have. The PO installed a 200" 6 out of a mustang, but I don't know what year it came from. The alternator is a one-wire (I assume internally regulated) but it doesn't have a plug. Rather it is directly wired to a junction box that is installed on the dog house, which I suspect is not stock. That box also has a power line from the battery and one going to the starter (and a ground strap from the box to the block). I don't think any of this poses a problem for the new harness, but any advice is welcome.
They also ask for what kind of steering column plug and turn signal plugs (Ford Model U, G. L W, etc) I have. Obviously I don't have a column ignition switch, but what about the turn signal? I guess I'll have to disassemble it at some point but I haven't so far and therefore can't see what kind of plug it needs. Again, suggestions???
Lastly, they ask for what kind of voltage gauge (voltmeter of ammeter) I have, which of course is none. I am going to add some aftermarket guages (temp, oil and voltage) so which way should I answer this question?
Sorry for all the questions. I've never rewired a vehicle before so this will be a new challenge. I'd like to make it as easy as possible so would like to order this correctly the first time. Thanks!
