G-Man wrote:I'm from Michigan and that van looks great to me, nothing there that can't be made to look great again
thanks for the encouragement
donivan65 wrote:Everything is fixable,,,,,,,it just depends on your skills, tools, knowledge, time, space, equipment and how much MONEY you have or want to spend,,,,,,,you do it because you want that van,,,,,,surely not to make a profit,,,,,,,
donivan65 wrote:Could be that is the charging system idiot light that someone stuck in the temp/oil hole in the dash,,,,,,,unplug the wire from the oil pressure switch by the dipstick,,,,,ground it,,,,,turn on ignition,,,,,the oil light should come on,,,,,,,,
donivan65 wrote:if the heater core is plugged, the area by the passengers feet will be cold,,,,,,,normally there is no shut off valve on a van,,,,,,200 degree coolant is always flowing into the heater and van,,,,,,I put a Bronco heater control valve in the heater hose to turn the flow of coolant on and off when I want,,,,,,see if you got a valve above the distributor,,,,,,
donivan65 wrote:[..]and its purpose is to come on AFTER you lost oil pressure or overheated the engine,,,,,,,you really need a voltmeter and a temperature gauge on your van to stop problems BEFORE they happen,,,,,,,you can leave the oil light on it,,,,but a gauge is useless,,,,,,,
Twinpilot001 wrote:cores are avail. also see youtube for cleaning a core out!!.Likely change out the old oil pressure sender if electric?? or clean the metal line to the gague if mechanical.
