    Homemade glovebox liner
    Homemade glovebox liner Empty Homemade glovebox liner
    Post by Guest Sun Sep 28, 2008 9:53 am
    So my van came with no glovebox liner, just a broken door. A parts van supplied me with a new door and a very deteriorated cardboard liner.
    I traced the old one to a piece of cardboard, cut it out, glued it together, added the factory thumbtack/nuts, painted it black and installed it! Oh ya, I added some seam sealer in the corners to reinforce them as some of the folds cracked the cardboard.
    A couple of the factory nuts broke out and I couldn't get the lower ones in, but the box is there and works well.
    Homemade glovebox liner Gloveb10
    Homemade glovebox liner Gloveb11
    Homemade glovebox liner Gloveb12
    Homemade glovebox liner Gloveb13
    Number of posts : 1148
    Homemade glovebox liner Empty Re: Homemade glovebox liner
    Post by jkr Sun Sep 28, 2008 10:49 am
    when you own an a-100 you got to be resourceful and creative.nice job. someone on here was selling metal ones for about $15 a while ago.??
    Post by Guest Sun Sep 28, 2008 4:03 pm
    You can get new ones, but they're like $25 now.
    Nice job though..looks good!
    Post by G-Man Sun Sep 28, 2008 6:13 pm
    Looks like $25 bucks saved!!! Nice job.
    Number of posts : 1135
    Post by benwah Sun Sep 28, 2008 6:20 pm
    nice job did you give it a coat of fiberglass resin to stiffen it up and stop the moisture? over time moisture does a job on cardboard
    Post by Guest Sun Sep 28, 2008 7:39 pm
    There's a good idea! I was thinking to myself "How can I make this thing stiffer or waterproof or something?"
    So just fiberglass resin with hardener I guess?
    Post by benwah Mon Sep 29, 2008 10:49 am
    i would sugest a "layer" of resin with a layer of the fiberglass "mesh" followed up with a coat of resin, on the outer part of the box . the inside id just use the resin. that should last a while.
    Number of posts : 2067
    Post by sasktrini Mon Sep 29, 2008 12:12 pm
    Great stuff! I've got to do this in my Ford too!
    Any chance I could get (buy) a pattern from you, Enbro?
    Post by benwah Tue Sep 30, 2008 7:29 am
    me too my sportsman doesnt have one
    Post by Guest Tue Sep 30, 2008 7:32 am
    As I put the old deteriorated liner in the garbage, the thought crossed my mind that others might want one. So I saved it. Everytime I touch it, more falls off it. It's really brittle.
    Perhaps I'll trace it onto some paper then I can just mail it to you? You have to cut and trim a little here and there. I used a hot glue gun to put it together, and there are factory nuts with teeth that were stuck into the cardboard, but I only managed to get 3 of them to work. Mounting into your dash will have to be a custom kind of thing.
    You have to remove the defroster duct to get it under there.
    Sound like a plan?
    Post by benwah Tue Sep 30, 2008 7:55 am
    thanks Enbro !! traceing it on paper will work fine. i have some pictures of the seats,. send me a pm with your email, ive got dial-up and limited smarts on computers its the only way i know how to send pictures.
    ViewMaster
    ViewMaster
    Number of posts : 117
    Post by ViewMaster Tue Sep 30, 2008 9:00 am
    Here is another idea I made years ago for a 2nd gen Chevy it's made out of plastic sign material, it's made from two sheets so there is more rivets showing then if I used one. It turned out super strong I glued some rubber on the bottom and was able to put speed nuts on it like the original that clip on the edge over the holes.
    Homemade glovebox liner C69c4
    Post by sasktrini Tue Sep 30, 2008 12:24 pm
    Great Enbro! An idea could also be if you could post a jpg of the pattern, and then we could download it!
    ViewMaster, that's nice!!!
    gp70
    gp70
    Number of posts : 162
    Registration date : 2008-05-22
    Post by gp70 Tue Sep 30, 2008 12:49 pm
    And this is my version of a homemade 2nd gen. Chevy glovebox
    http://www.vintage-vans.com/gbox.html
    Post by sasktrini Thu Oct 02, 2008 2:29 pm
    That's awesome!
    gp70 wrote:And this is my version of a homemade 2nd gen. Chevy glovebox
    Post by Guest Thu Oct 02, 2008 6:50 pm
    Just give me a couple of days to get some large construction paper to trace this thing onto.
    Post by Guest Tue Feb 19, 2013 6:51 am
    Hate to dig up an old thread, but before I drop $35 + $15 shipping on one from eBay, I wanted to see if this pattern / template got posted anywhere or if I could still get my hands on one.
    rebar
    rebar
    Number of posts : 151
    Post by rebar Sun Feb 24, 2013 8:29 pm
    Mine kinda disintegrated a while ago. Gently took the remaining pieces and made a replica cage out of 1/8" square screen, covered it with bondo and embedded the original screw clips. That sucker ain't fallin' apart on me again...
    Post by Guest Tue Feb 26, 2013 8:40 am
    I got mine in yesterday and was eager to install it. Went outside in the dark with a flashlight only to realize that I am going to have to remove something to get it installed. I am hoping I can just pull the dash pad and slip it in through the glovebox door. Otherwise I will have to disconnect the big vent under the dash.
    I also realized that I am going to have to get some kind of clips that attach around the edge of the opening for the screws to go in to.
    Post by Guest Tue Feb 26, 2013 3:56 pm
    I've removed both the dash pad and the glovebox door and there is no way this thing is fitting in there. I tried going up from underneath but with the big vent down there it is just way to tight. Am I going to have to remove that vent system in order to get this glovebox in or is there some trick that I'm not familiar with?
    Homemade glovebox liner Glovebox
    Any help would be appreciated.
    rebar
    rebar
    Post by rebar Tue Feb 26, 2013 10:02 pm
    To install mine I removed that square vent/heater duct under the dash. 2 of the top 3 screws that head toward the front cowl are tough to get back in so I just left them out, a couple decades ago, and it hasn't had any negative effects. 2 of the top screws going into the heater housing only need to be loosened because the holes in the duct are slotted, or, half-holes so that the duct can slide in and out without having to re-insert the screws from an impossible position. Takes a little time and patience, but while you're in there you might want to check all the connections on the heater pipes, etc.
    rebar
    rebar
    Post by rebar Tue Feb 26, 2013 10:11 pm
    Most auto parts stores carry a variety of similar clips. You may have to improvise - maybe use some goop to hold them in place.
    Post by Guest Thu Feb 28, 2013 5:42 am
    I got everything I need but am going to save this project for the weekend. I might as well clean and repaint the metal heater housings on that side while they are out.
    Thanks for the info and tips, Rebar.
    Post by Guest Wed Mar 06, 2013 10:36 am
    nate the skate wrote:You can get new ones, but they're like $25 now.
    I got a OEM one from George geissinger in PA !!
      Current date/time is Fri May 10, 2024 7:40 pm
