    It is getting cold and I have no heat!!!
    Number of posts : 339
    It is getting cold and I have no heat!!! Empty It is getting cold and I have no heat!!!
    Post by lectricman Sun Sep 26, 2010 4:51 pm
    OK... here is the problem... The heater core leaks.... lol.... I can not find a replacement core... I have the box set up in the floor in my '62... I had another box and tore it apart and someone soldered it up around the temp control and took the temp control out???? I assume it was leaking around it??? Don't know??? I brought the auto parts stores transpro radiator/heater core/AC condenser book home and can not find anything that even resembles what I need.. (one with the temp control) I guess the question is.................
    What is everyone using for a heater core in the little box heater that is mounted to the floor in our Econolines????????? Do you think that a radiator shop can find the leak/leaks in my unit and fix them???? any suggestions or stories on what you have done for your heat is greatly appreciated.... Thanks guys............
    Number of posts : 1319
    It is getting cold and I have no heat!!! Empty Re: It is getting cold and I have no heat!!!
    Post by 67a 100 pickup Sun Sep 26, 2010 5:24 pm
    Your cores were talked about awhile back in "between the seats 'e' " type in heater core in the search block and the posts will come up. Good luck.
      Current date/time is Sun May 19, 2024 6:16 am
