    COLD air induction?
    Donn
    Donn
    Number of posts : 692
    COLD air induction? Empty COLD air induction?
    Post by Donn Tue Oct 08, 2013 4:49 pm
    Anyone ever try to set up a cold air induction on an early?
    Looking for ideas
    Number of posts : 277
    Registration date : 2011-01-20
    COLD air induction? Empty Re: COLD air induction?
    Post by Lyrad Tue Oct 08, 2013 5:59 pm
    Dido I think that would be awesome aswell.
    Number of posts : 1778
    Post by m1dadio Wed Oct 09, 2013 9:48 pm
    COLD air induction? Dscn0310
    COLD air induction? Dscn0311
    COLD air induction? Dscn0312
    I originally had this made with that corrugated dryer vent tube
    COLD air induction? Dscn0110
    The dryer vent tube corrugations caused air restriction and the engine literally ran out of air and couldn't go past 4700rpm loss of hp and torque
    The strait smooth aluminum tubing allowed air flow to 5800 rpm as proven on the dyno
    https://s119.photobucket.com/user/m1dadio/media/DSCN1408.mp4.html?sort=3&o=10
    https://s119.photobucket.com/user/m1dadio/media/DSCN1407.mp4.html?sort=3&o=40
    You can see on the recorded results, a 1200 rpm gain, a 12.5 hp gain and  4.8 ft/lbs torque gain but more importantly the HP peak moved into a higher rpm rang and the torque curve became stronger at lower  rpm with a broader curve spread out over a wide rpm range.
    https://s119.photobucket.com/user/m1dadio/media/DSCN0240-1.jpg.html?sort=3&o=76
    https://s119.photobucket.com/user/m1dadio/media/HPTQ.gif.html?sort=3&o=41
    the most important improvement is now the torque peak is now at the bottom of the rpm curve which now enabled this to happen.
    https://s119.photobucket.com/user/m1dadio/media/DSCN1423.mp4.html?sort=3&o=21
    All in all, forget going cheep, you will only pay with increased gas mileage and less power with dryer duct.
    Your don't need silicone rubber, that's for turbo and high heat, the black rubber is all you need.  here is the best deal.
    http://intakehoses.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=CU9
    M1D
      Current date/time is Tue May 07, 2024 11:27 am
