    A-100 Pickup - question on dash pad
    blackace
    blackace
    Number of posts : 450
    A-100 Pickup - question on dash pad Empty A-100 Pickup - question on dash pad
    Post by blackace Fri Sep 17, 2010 11:44 am
    I was wanting to find out if anyone could give me some info on the dash pad that I have on my 68 pickup. I have seen trucks without them and was not sure if this was a special option or if they all had them and were taken out?
    Number of posts : 3046
    A-100 Pickup - question on dash pad Empty Re: A-100 Pickup - question on dash pad
    Post by RodStRace Fri Sep 17, 2010 1:16 pm
    i think they were part of the safety equipment for later years.
    SnarkyPoet
    SnarkyPoet
    Number of posts : 174
    Registration date : 2009-12-22
    Post by SnarkyPoet Fri Sep 17, 2010 2:00 pm
    Dash pads, backup lights, dual-circuit brakes, and lap-belts were all added in '67 as the result of new safety regulations.
    blackace
    blackace
    Post by blackace Fri Sep 17, 2010 2:17 pm
    SO what you are saying is that it is the 60's verison of an air bag, just with out the air.. Know I would not want to hit my face on it.
    Post by RodStRace Fri Sep 17, 2010 2:21 pm
    blackace wrote:SO what you are saying is that it is the 60's verison of an air bag, just with out the air.. Know I would not want to hit my face on it.
    Metal dash or padded, bendable wing. A small step, but better than without!
    Remember, no 3-point belts in wide spread use yet.
    inside door handles changed too.
    blackace
    blackace
    Post by blackace Fri Sep 17, 2010 2:24 pm
    is there a good product to use to bring back that luster of the plastic overs on the doors and this pad. I would like to get a shine back on them as I have washed them but they are still dull looking
    Post by G-Man Fri Sep 17, 2010 4:52 pm
    Armor - All
    Number of posts : 8732
    Post by dix Fri Sep 17, 2010 5:33 pm
    ON THE DOOR PANELS I USED A SPRAY BOMB CLEAR FROM THE LOCAL HARDWARE STORE. THEY LOOK GREAT. I HAVE NOT DONE ANYTHING YET I WOULD GUESS SAMETHING WILL DO JUST FINE. TRY IT ON THE UNGERSIDE.
    Post by RodStRace Fri Sep 17, 2010 5:48 pm
    Armor all is solvent based and will dry stuff out!
    Scrub gently with mild soap and water to get all the junk off.
    Inspect to determine if the original surface is still in good condition.
    If it is, use a water based vinyl dressing.
    If it's just faded, a vinyl paint can cover it. Do not use vinyl dressing after, it's paint now!
    If the surface is rotted and/or brittle, you need to find replacements for a restoration.
    For something modified, you can cover with material or go with fiberglass covered with material, paint or even create a new part.
    Post by G-Man Fri Sep 17, 2010 8:02 pm
    Never had a problem with Armor All , it's not solevent based , it's silcone based
    What are the ingredients in Armor All® Protectants? Do they include silicone, alcohol, ultraviolet inhibitors and petroleum distillates?
    Armor All® Leather Care contains lanolin and natural moisturizers, and UV inhibitors. Armor All® Leather Care Protectant Spray and Leather Wipes contain water-based silicone emulsions, surfactants, and ultraviolet light inhibitors. Armor All® Original Shine Protectant contains water-based silicone emulsions, surfactants, and ultraviolet light inhibitors, humectants, dispersants and gloss enhancers. Armor All® Ultimate Clean Protectant contains water-based silicone emulsions, surfactants, ultraviolet light inhibitors and a fragrance.
    blackace
    blackace
    Post by blackace Sat Sep 18, 2010 10:22 am
    Thanks for all the advice. I will try a few of your suggestions and see what works out the best. i will get pics of the before and after and post them with my other pics.
      Current date/time is Mon May 20, 2024 6:25 am
