I need to pull the axels from the parts van rearend any sugestions on how to remove the c clips that hold them in.Thanks Bill
axel c clip removal
axel c clip removal
Re: axel c clip removal
Bill, There is a 5/16" pin thru the shaft that the spider gears rotate on. Pull this pin and slide the shaft out enough to push the axle in toward the center and you can remove the c-clip with a magnet. Becarefull not to pull the spider axle shaft out to far, as the spider gears and shims will come out.
Thanks! Got it . Bill
