    Time for a HEI
    Number of posts : 1388
    Time for a HEI Empty Time for a HEI
    Post by wideload Tue Aug 17, 2010 2:13 pm
    The 65 laid down today while I was running a short errand. They don't run to good when this happens!!!!
    Time for a HEI 100_3811
    The points cam assembly came off of the dist. shaft.
    Time for a HEI Empty Re: Time for a HEI
    Post by Nightmoves Tue Aug 17, 2010 6:23 pm
    Wut Whoa! I dont think duct tape is gonna fix that one buddy. Laughing
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370381074998&viewitem=&sspagename=STRK%3AMEWAX%3AIT
    That might hep ya out.
    Number of posts : 7900
    Post by DanTheVanMan Tue Aug 17, 2010 7:07 pm
    Same company I got mine from for the 250. Out of Tenn.. Mine works great!!!!
    Time for a HEI Qr_cod10
    Post by DanTheVanMan Tue Aug 17, 2010 7:16 pm
    Post by Nightmoves Tue Aug 17, 2010 7:35 pm
    That one I bought was posted on here and they said they were good folks too if any troubles.
    Mike,you said thats the only one of the herd that didn't have HEI.So I reckon its time.
    Post by wideload Wed Aug 18, 2010 3:19 am
    Thanks for the links guys !!! But the 65 is also the only one of the heard that has a V8. I'm going to check the local yards and try to pickup a stock GM one.
    What kind of ignition module, rotor button, and cap do the aftermarket ones use? That's why I'm going to go with a stock one.
    Post by Digz Wed Aug 18, 2010 3:44 am
    On used HEI's , It took 3 to make one good one when I set one up, probably was just my luck but still somethin to keep in mind.
    Post by wideload Wed Aug 18, 2010 7:17 am
    Did a little research and decided that Digz had a good point. I'm going to go with this setup.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350358147244&viewitem=&sspagename=STRK%3AMEWAX%3AIT
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350371957635&viewitem=&sspagename=STRK%3AMEWAX%3AIT
    With this I shouldn't have any doghouse clearance problems.
    Post by donivan65 Wed Aug 18, 2010 9:36 am
    I just put one of those in a 68 Camaro,,,,,it still needs an HEI external coil,,,,,,,
    Time for a HEI Pictur11
    Number of posts : 1651
    Post by Scott Wed Aug 18, 2010 10:00 am
    Hey Donivan,
    What external coil did you use in the Camaro?
    Post by donivan65 Wed Aug 18, 2010 11:37 am
    It came from the same place,,,,WhitePerformance1,,,,,its a high output remote coil,,,,,another thing different about those distributers is the spark plug wire holes in the cap ,,it could have male or female terminals,,,you need the right type wires to plug into the cap,,,,,,I had to choose and install the correct terminals on the ends of the wire set ,,,,,,
    Post by wideload Wed Aug 18, 2010 12:41 pm
    Thanks for the heads up Don !!! I didn't realize I needed a different coil also.
    Post by donivan65 Wed Aug 18, 2010 1:31 pm
    Wideload, That red one ain't exactly the best thing out there,,,,I think it's transistorized,,,,,where do you get parts WHEN it dies,,,,,,if you don't have room,,,,,you could use the 1st edition HEI with the separate coil and have common available GM parts,,,,,,and you always need a back up for the road,,,and I think thats what I keep tripping over in my garage,,,,,the original 350 points distributer from the 68 which has been converted over to Petronix. I will give it to you next time I see you or mail it to you when you are stuck along side the road,,,,,,,,
    Time for a HEI Repair46
      Current date/time is Wed May 08, 2024 8:12 am
