    Engine Temp Sensor Locaton
    Linoman
    Linoman
    Number of posts : 329
    Engine Temp Sensor Locaton Empty Engine Temp Sensor Locaton
    Post by Linoman Tue Aug 03, 2010 11:21 am
    Is there more than one spot on the Ford 240 six for a temp sensor?
    Number of posts : 2067
    Engine Temp Sensor Locaton Empty Re: Engine Temp Sensor Locaton
    Post by sasktrini Tue Aug 03, 2010 5:49 pm
    It's tapped at the back passenger side of the block... but most others are at the thermostat housing, after also absorbing heat from the head... I would guess if you were going with an aftermarket temp gauge, you might have to use a location at the front of the head... I don't know if they make thermostat housings tapped for a coolant temp sensor... is that what you are looking for?
    Join FordSix.com Forum That is where I get all my information on small Falcon Sixes and the Big Sixes!
    Last edited by sasktrini on Tue Aug 03, 2010 5:52 pm; edited 1 time in total (Reason for editing : http://www.fordsix.com/forum)
      Current date/time is Tue May 07, 2024 9:52 am
