    Will a truck steering colunm fit a van
    redsockss
    redsockss
    Number of posts : 123
    Registration date : 2010-06-03
    Will a truck steering colunm fit a van Empty Will a truck steering colunm fit a van
    Post by redsockss Sat Jun 19, 2010 12:41 am
    Will a truck steering colunm fit a van Empty Re: Will a truck steering colunm fit a van
    Post by Guest Sat Jun 19, 2010 12:44 pm
    call or email someone like ididit or flaming river they specialize in columns.
    redsockss
    redsockss
    Post by redsockss Sat Jun 19, 2010 12:56 pm
    Heck, you hear so many things. The people on here are brilliant about what will and what will not work.
    Number of posts : 801
    Post by panelmanrd Sat Jun 19, 2010 1:50 pm
    early chevy van steering columns are part of the steering box,
    they will not interchange with out modifacation.
    Post by donivan65 Sat Jun 19, 2010 7:54 pm
    You get the shaft with those new steering columns,,,,,,the thing is, you already have 2 of them,,,,,,,so you would have to cut the shaft off the steering box and connect the steering column to it,,,,,,,and then there is the shift lever shaft,,,,,,it is part of our steering columns,,,,,so what do you do for shifting? I think if you took the whole column and shift lever assembly out of a 2nd gen, (67-70), it would fit and work on a 1st Gen, (64-66).
    Will a truck steering colunm fit a van Pgleve13
    Will a truck steering colunm fit a van Pgleve14
    Post by G-Man Sat Jun 19, 2010 8:22 pm
    I just got a ididit column , I'm going to have to cut the shaft then put a union on to make the two go together. Ididit has everything you need to do the job
    Post by donivan65 Sat Jun 19, 2010 11:40 pm
    And what do you use for a shifter?
    Post by G-Man Sun Jun 20, 2010 4:24 am
    I'm going to have a floor shifter, I'm looking at the Locar shifts. Very well made and all USA parts
    Post by Guest Sun Jul 03, 2011 3:56 pm
    G-man, what length column did you get from ididit?
    Post by G-Man Sun Jul 03, 2011 7:50 pm
    30"
    Number of posts : 1651
    Post by Scott Tue Jul 19, 2011 7:07 pm
    G-Man wrote:I'm going to have a floor shifter, I'm looking at the Lokar shifts. Very well made and all USA parts
    I put a Lokar in my van, it works, but I had to find a 13' cable to run back to the transmission.
    The B&M Shifter I bought wouldn't work, it would just bind. When your ready, and if you want to know, I'll look up the one I bought.
      Current date/time is Fri Apr 26, 2024 11:00 am
