    Speedo cable help.
    Speedo cable help. Empty Speedo cable help.
    Post by Guest Tue Apr 20, 2010 5:09 pm
    I swapped my manual trans for a 200r4. Now my speedo cable does not fit into the trans hook up. The cable is too small. I tried switching the plug or speedo gear housing from the manaul trans to the 200r4 but that was too small as well.
    Questions:
    Can I just swap the plastic speedo gears from one to the other?
    or
    Can I purchase or salvage one that could work?
    Any suggestions would be appreciated.
    Thanks!!
    Number of posts : 1388
    Speedo cable help. Empty Re: Speedo cable help.
    Post by wideload Wed Apr 21, 2010 4:17 am
    Gator I'm not sure what the correct parts are but I know it can be done. Billski did the same swap. You might try sending him a PM.
      Current date/time is Tue May 07, 2024 7:11 am
