    Ritchies 66 GMC
    richie61
    richie61
    Number of posts : 445
    Ritchies 66 GMC - Page 3 Empty Re: Ritchies 66 GMC
    Post by richie61 Thu Apr 15, 2010 12:47 pm
    It was me!
    Post by Guest Thu Apr 15, 2010 12:53 pm
    sounds like you need to buy the rest of my parts van Richie, ROFLMAO!!
    richie61
    richie61
    Post by richie61 Thu Apr 15, 2010 1:02 pm
    If I had the $$$$ I would. How does that rear axle look on it???
    Post by Guest Thu Apr 15, 2010 1:55 pm
    richie61 wrote:If I had the $$$$ I would. How does that rear axle look on it???
    Drove it onto the trailer from the back 40, havent really paid much attention to it other than that. I'll take a look at it tonight when I get home, I know its a 10 bolt.
    Number of posts : 1778
    Post by m1dadio Thu Apr 15, 2010 7:25 pm
    I talked to the guy who has the airfilter assembly. He says he will see if he can get it back to me.
    M1D
    richie61
    richie61
    Post by richie61 Thu Apr 15, 2010 8:43 pm
    Thanks
    Post by Guest Thu Apr 15, 2010 9:22 pm
    The diff seems to be in good condition. I have not pulled the cover off, but there doesnt seem to be any play out of the ordinary.
    richie61
    richie61
    Post by richie61 Thu Apr 15, 2010 9:30 pm
    OK thanks..let me know when you pull the cover and see whats inside. Did you buy this van strictly for parts originally?
    Post by Guest Sat Apr 17, 2010 3:43 pm
    richie61 wrote:OK thanks..let me know when you pull the cover and see whats inside. Did you buy this van strictly for parts originally?
    Yup.....will do, and yes bought for parts. Thought about bringin it back. Dont need 2 GM vans.......maybe a P/U next.
    richie61
    richie61
    Post by richie61 Tue May 04, 2010 11:46 am
    Got everything back together and no spare parts left. Glad I took pictures of the brakes since it's been 30 years since I had drums. Added six 90lbs bags of cement in the rear to lower it and push the driveshaft in...thanks Don. Have a project to use them later at home. Have to change the gas line. A shop want's $5 per foot for a new stainless steel line. Any other options like brakelines? I want to change it I think it's full of rust.
    Post by Digz Tue May 04, 2010 5:37 pm
    check on the 5ft sections of brakeline, think you can get that ina stainless , I used 2 chunks with a union in the middle, Just make darn sure the union is tight. I found out "just snug" leaks.
    richie61
    richie61
    Post by richie61 Tue May 04, 2010 7:44 pm
    That's what Don said to do. It's probably a lot cheaper too. Did you use some type of sealer on the threads??
    Post by Digz Tue May 04, 2010 8:07 pm
    No, the actual seal is done by the flare on the tubing and where it seats.
    Post by donivan65 Tue May 04, 2010 8:12 pm
    Napa might sell that 5/16" brake tubing by the foot,,,,,,for your gas line,,,,,,,measure it from the tank to the fuel pump,,,,,it might be 60" which is the longest the brake lines come in,,,,,,,,
      Current date/time is Thu May 02, 2024 6:04 am
