    Rear End Gear Lube Q
    Rear End Gear Lube Q Empty Rear End Gear Lube Q
    Post by Digz Tue Apr 06, 2010 6:02 pm
    I just put the standard heavy gear lube like we use in everything in my 4:11 posi. What is supposed to go in there, or will that be okay?
    G-Force
    G-Force
    Number of posts : 56
    Registration date : 2010-04-02
    Rear End Gear Lube Q Empty Re: Rear End Gear Lube Q
    Post by G-Force Tue Apr 06, 2010 8:29 pm
    Good question! I'm about to freshen up all the juices in my van too and this would be great info. -John
    Number of posts : 1778
    Post by m1dadio Tue Apr 06, 2010 9:37 pm
    once upon a time posi fluid was different then regular hypoid oil. Now the gear oil sold is said to be good for both. But thats because the materials used in modern posi and limited slip gears is a modern materil whos coeficient of friction is not changed by the gear oil produced today.
    But I don't know if that applies to old time clutch materials.
    M1D
    GreyFoxMC
    GreyFoxMC
    Registration date : 2008-06-02
    Post by GreyFoxMC Wed Apr 07, 2010 3:17 am
    I have always used an additive when changing lube in a posi.
    Rear End Gear Lube Q Yb
    Number of posts : 3046
    Post by RodStRace Wed Apr 07, 2010 9:15 am
    Yes, the original anti-friction additive was made from stuff we are not supposed to kill anymore. The best stuff available now for posis that I know of is the GM additive.
    For the rest of the fluids, you can try some or the various synthetic lubricants, but go with a brand that has been around a while and is proven. There is a reason why 'snake oil' is a term indicating a bunch of hype!
    Redline, Amsoil, and Royal Purple have been around long enough to have been proven to work. There are others, I haven't used any to give you first hand results.
    Post by Digz Wed Apr 07, 2010 6:54 pm
    "stuff we are not supposed to kill anymore" Do you mean Whale oil ? I had a friend tell me that the other day, I had never heard of it. Going for the additive for now. I am picking up some noise in the rear end, put a stethoscope on it today and I may be changing out those pinion bearings I "thought were okay". Thanks guys, for the input.
    Joe
    Post by RodStRace Thu Apr 08, 2010 7:07 am
    Post by Guest Wed May 05, 2010 12:30 pm
    Lubrication Engineers.
    These guys are NOT cheap, but their products are what Ski Areas use in the gear boxes of Chair Lifts when hundreds of lives are 'on the line' literally!
    LE Automotive Products
    The higher end stuff is good for three quarters of a million miles... Shocked
      Current date/time is Tue May 07, 2024 1:30 am
