Rear-end "Gear Swap" ........
Number of posts : 7732
Post by DanTheVanMan on Fri Jul 10, 2015 6:01 pm
Looking at swapping the 3:36's our for some 3:08's.. Anyone have a source? Info or advice on making this swap?
Thanks,
Dan
Snakebite88
Number of posts : 20
Registration date : 2014-04-27
Re: Rear-end "Gear Swap" ........
Post by Snakebite88 on Sun Jul 12, 2015 3:50 pm
I bought a 336 ring, pinion and master install kit from this place. Was about $285.00 in all...looks like they sell a 308 also.
http://www.ronsmachiningservice.net/gm-8-2-chevy/
Post by DanTheVanMan on Sun Jul 12, 2015 4:36 pm
Cool! Thank you! cheers
Xelmon
Number of posts : 343
Post by Xelmon on Sun Jul 12, 2015 5:33 pm
Particular mfg:
Yukon and Richmond are out there and I've heard that both are solid bets.
Van axles:
In general we got GM 8.2" rears with 1.400" pinion diameter. So if it says 1.628 or as such, that won't fit.
General RPO swap notes:
If you do that there's a somewhat expansive list of things you need.
In no particular order;
* New RPO (duh)
* Set of shims
* Pinion bearing
* Micrometer
* Paint
* Setting bearing
* And maybe a pinion seal... Don't recall.
Point is that it's not too complicated, however you'll need a ton of patience to set the backlash correctly. The Setting bearing is also a good to get, which is like $50 or so. It is necessary to be able to be able to setup your shims correctly, as you can remove it and measure/swap out shims multiple times to get a great mesh.
Otherwise you are guessing with pressing in a bearing, and destroying it when you have to pull them out if things are off.
Different between a thrown-together and properly-setup axle is also staggering. A setup axle will go for... ever, while a thrown-together axle can easily grenade itself in 500 miles or so from what I've heard.
Reading material:
Yukon gear's general assembly:
https://www.yukongear.com/Downloads/Manuals/Yukon_General_Installation_Instructions.pdf
More Yukon reading:
https://www.yukongear.com/Manuals.aspx
Read around the internet, there are some great guides out there dealing with say, a Dana-44 or 60 swap. They are roughly the same concept, just different numbers.
Post by DanTheVanMan on Sun Jul 12, 2015 9:24 pm
Good info Xelmon! Thank you! study
Snakebite88
Post by Snakebite88 on Mon Jul 13, 2015 3:28 pm
When you buy a gear set, make sure it's the Chevy 8.2 and not the BOP 8.2. The BOP won't work.
    Current date/time is Mon Apr 23, 2018 6:06 am
