+7
Hangtime
11 posters
    Texas Johns 8 Door E Project...
    Number of posts : 672
    Texas Johns 8 Door E Project... Empty Texas Johns 8 Door E Project...
    Post by texasjohn Tue Mar 02, 2010 8:42 pm
    This is where i'll post progress and pictures for this vanas it gets done....
    1966 Ford Falcon E, 240 w/ 3spd.
    3-1-10...Got it in the driveway. After sitting for a month or so, i put a battery w/ 9volts left in it and on the 3rd or 4th rev. it fired right up. No brakes thoug. I used it to pull the 66 brown supervan from the driveway to the backyard. Motor seems to run decent. Havnt had it on the road yet. Thinkit needs an alt or regulator since it started smoking when i hooked upthe battery backwards...ooops. FYI, batt cables are/can be different fromone van to another....someone could have put different cables on over the years....track them back to where they came from.
    Texas Johns 8 Door E Project... 11-31-09_004.33491158_large
    Texas Johns 8 Door E Project... 11-31-09_015.33491451_large
    Texas Johns 8 Door E Project... 11-31-09_011.33491925_large
    Texas Johns 8 Door E Project... 11-31-09_012.33492055_large
    Texas Johns 8 Door E Project... Empty Re: Texas Johns 8 Door E Project...
    Post by texasjohn Wed Mar 17, 2010 12:39 am
    3-14-10...Compession test,,100,130,125,110,120,110. Took rear doors off other panel to put on this one after sanding and priming. Also started to bleed brakes...then it got dark.
    Texas Johns 8 Door E Project... 3-15-10_001.74233947_large
    full build process at http://www.8thdaycycles.com/1966_8_door_van
    Number of posts : 3046
    Post by RodStRace Wed Mar 17, 2010 8:56 am
    texasjohn wrote:This is where i'll post progress and pictures for this vanas it gets done....
    long hair freak flag flyin', Check
    Flannel shirt, Check
    torn, soiled jeans, Check
    big ol' work boots, Check
    happy van owner looking forward to gettin' her rollin cool again, Oh Yeah!
    Post by texasjohn Mon Mar 22, 2010 9:51 pm
    laffing my a$% of at ur responce, Check.
    3-22-10...Got the brakes done today. Just a major flush and bleed. Working good, we'll see if i got a puddle tommorow. Didnt see any leaks....Ran around the block a few times. seems to be running fair. Still have alt light glowing, system is overcharging at 15.56v. Probally because i hooked batt up backwards....ooops
    Texas Johns 8 Door E Project... Crossedeyed.44122406
    WHAR DO I PUTS DIS CABEL??????
    Number of posts : 466
    Post by Sy Hollinshead Tue Mar 23, 2010 12:10 am
    Hey, thanks for the pics. I have one of those spare tyre brackets that you have on the back of yours. It came with a load of spares for my van and i had absolutely no idea what it was until just now when i saw yours.... Smile
    Hangtime
    Hangtime
    Number of posts : 64
    Registration date : 2008-09-11
    Post by Hangtime Wed Mar 24, 2010 8:01 pm
    How many vans is that for you now? If I had more space I can see how it would be easy to amass amany.
    Post by texasjohn Wed Mar 24, 2010 10:37 pm
    i now have 8 1st generation E's. and myeyes on 2 more.....i thinkits enough but i cant help it......I see what there going for and i got to get them....Plus i love em. If i had a job i'd probbly have more.......
    Last edited by texasjohn on Wed Mar 24, 2010 10:38 pm; edited 1 time in total (Reason for editing : forgot something)
    Post by texasjohn Fri Mar 26, 2010 1:35 am
    liic and insured, been driving it for two days. throttle sticks a little but runs good. Got home tonight and brakes felt a little soft, no fluid in master cylinder so theres a leak somewhere. Gonna get a rebuild kit then start rebuilding the whole brake system.....soon i hope. Found a two post lift for 500 bucks so im buying it this weekend. Anyone want to help poor a slab?????
    Number of posts : 2067
    Post by sasktrini Fri Mar 26, 2010 9:22 am
    sounds like a great deal on the lift!!! That oughta make it a little easier to do your brake work!
    Post by texasjohn Sun Mar 28, 2010 10:19 pm
    as long as i carry extra DOT 3 the brakes are awesome....
    Number of posts : 1422
    Post by Magic Bus Tue Mar 30, 2010 4:29 pm
    texasjohn wrote:laffing my a$% of at ur responce, Check.
    Now thats FUNNY!
    Post by texasjohn Mon Apr 05, 2010 12:54 am
    put rear wheel cylinders in today, fixed those leaks. master cylinder's still leaking. King pins are shot.
    Post by texasjohn Wed May 19, 2010 10:13 pm
    i need a master cylinder for this.....NEW, " Auto SUCK Zone" cant get it right....
    Post by Nightmoves Wed May 19, 2010 11:30 pm
    I've learned the hard way at auto zone,if its behind the counter,I dont buy it.
    Post by texasjohn Fri May 28, 2010 1:00 am
    seriously, i need a master cylinder for this.......
    Post by RodStRace Fri May 28, 2010 6:39 am
    Rockauto.com
    1966 FORD ECONOLINE 3.9L 240cid L6 : Brake/Wheel Hub : Master Cylinder
    CENTRIC Part # 13065007 {Centric Premium}
    * Non-stock item--shipping delayed up to 2 business days $94.79
    WAGNER Part # MC36313
    1/2 Ton; w/Man. Brake; 1" Bore
    * Non-stock item--shipping delayed up to 3 business days $123.99
    Post by texasjohn Fri May 28, 2010 9:52 pm
    dang....go a rebuild kit??????
    Post by RodStRace Sun May 30, 2010 6:47 am
    You can take it apart and check if it will take a rebuild...
    You seem to be a good wrench and already know this, but check the bottom of the bore for rust and damage. Water and crud settle to the bottom and that's where the damage will be.
    At least you have part #s now.
    Brake stuff isn't flashy and cool like wheels and chrome, but without brakes it has to sit in your yard.
    Number of posts : 355
    Registration date : 2010-05-30
    Post by toad Sat Jun 12, 2010 1:54 am
    Check NAPA. They had one on the shelf when I called. http://www.napaonline.com
    Post by texasjohn Sun Jun 13, 2010 7:39 pm
    Well, sold the van today, hated to see it go, but the 61 e pickup is top of the list. gave ryan the keys and a big bottle of DOT3....he has about 300 miles to go,
    Post by texasjohn Sat Nov 20, 2010 9:55 pm
    Ryan got a little work done on the ol girl....
    1) as sold to ryan....
    Texas Johns 8 Door E Project... Ryan_11-11-10_A.317225346_large
    2) quick paint job
    Texas Johns 8 Door E Project... Ryan_11-11-10_B.317225625_large
    3) fun paint
    Texas Johns 8 Door E Project... Ryan_11-11-10_C.317230027_large
    4) custom baby
    Texas Johns 8 Door E Project... Ryan_11-11-10_D.317230316_large
    5) interior work
    http://www.8thdaycycles.com/yahoo_site_admin/assets/images/ryan_11-11-10_E.317230428_large.JPG
    Number of posts : 917
    Post by wylee Sun Nov 21, 2010 3:42 am
    very cool.........................
    Number of posts : 1135
    Post by benwah Sun Nov 21, 2010 8:22 am
    Yup Im digin it! Cool
    Post by Guest Sun Nov 21, 2010 3:14 pm
    looks good but why didn't he do the body work??
    Post by texasjohn Sun Nov 21, 2010 7:05 pm
    i dont know, but i knew i shouldnt have sold it. Last i talked to him he was about to drive it to southern cali from idaho....
      Current date/time is Wed May 01, 2024 4:28 pm
