window seals
window seals
RobSWD- Number of posts : 52
Registration date : 2010-02-04
Re: window seals
Nice! How hard was it to do and which company did you use? Any pointers?
Re: window seals
Macsautoparts.com has all of them including rubber for all doors.
Re: window seals
You got some tricks or tips on installing the rear window. I got the front one in with no problems but the back one leaks the driverside upper corner Is not sealed properly, should I spray the seals down with something a try to move it around till it goes in place?
Re: window seals
Try Silicon Spray and wiggle the gasket around and see if it finds a happier place to settle into
Re: window seals
Alright I pulled the window back out and cleaned the seal cleaned the lip on the frame . Then I put it back in and now it looks like it is sitting in there all the way now, but it still leaks. Anybody got an suggestions? Has anyone else had issues with the back window seals from MACs?
Re: window seals
Well what it is looking like is the corner of the seal is streached out I can get it to go down but it will still leak and it works it's way back up. Looks like I am going to have to get a new seal that sucks because this one is only like a year and a half old, but I have pulled it out about 3 times.
Re: window seals
Before you get a new one, stop by a glass shop and see if they can do anything for you.
