+16
ChevyVanMan1
Vanadian
20 posters
    BILLS66 VAN
    BILLS66   VAN - Page 4 Empty Re: BILLS66 VAN
    Post by Nightmoves Wed Jan 05, 2011 3:38 am
    Will an aftermarket CalCustom/Moroso type,valve cover plug fit that hole? Look close to same dia..Just a thought.
    Number of posts : 1383
    Post by BILLS66 Thu Jan 06, 2011 5:28 pm
    Well the holidays are over back to work on the van ! I have had all the ceiling panels in place for a month and the other day I got the correct headliner material from a buddy of mine that does auto uhpolstery and a few tips. I pulled down one of the panels and cut and glued the material and just bolted that up .WOW it loooks great I can't wait to finish the rest.As soon as the rest of the material arrives I will have this done in no time. Bill
    BILLS66   VAN - Page 4 001-15
    Number of posts : 956
    Post by slowflapper Fri Jan 07, 2011 6:47 am
    whats that material called? I was thinking about using "speaker carpet" on my roof and walls.
    Post by G-Man Fri Jan 07, 2011 7:25 am
    Looks good Bill!!!
    Number of posts : 7900
    Post by DanTheVanMan Fri Jan 07, 2011 9:51 am
    Very cool Bill That headliner is going to be amazing!!!!
    BILLS66   VAN - Page 4 Qr_cod10
    Post by Guest Fri Jan 07, 2011 4:45 pm
    Lookin good! I still need to do mine. What wood did you use up there?
    Post by BILLS66 Fri Jan 07, 2011 5:25 pm
    Thanks everyone,This is a job anyone can do(even me).slowflapper don't know what the name of the material is but its a cloth type with the padding on the back.Oh and just to be safe I used a spray glue that is moisture resistant(picked it up at an automotive supply store).BALCONES1 The wood is a very thin luan that is water resistant that I got at Home depot and it is very easy to work with. Bill
    Vanadian
    Vanadian
    Number of posts : 187
    Registration date : 2010-11-17
    Post by Vanadian Thu Jan 13, 2011 7:51 am
    Bills66, did you only do the front disc brake conversion? I looked back and only saw pictures of front disc only, but I saw you had the wheels off front and back on the hoist. I now assume thats because of the custom wheels...Right?
    Post by BILLS66 Thu Jan 13, 2011 3:44 pm
    Vanadian,I had the rear bearings and brakes (drum)done and at that time and my good friends that did the work talked me into doing front discs and dual master cyl . Bill
    Vanadian
    Vanadian
    Post by Vanadian Fri Jan 14, 2011 7:17 am
    Thats pretty much what happened to me, too. Well worth the $$$. Has anybody found a rear disc brake set up that works?
    Post by Digz Fri Jan 14, 2011 1:09 pm
    This is what I used for the rear brakes. http://cgi.ebay.com/ebaymotors/GM-Rear-Disc-Brake-Conversion-Kit-10-12-Bolt-A-F-X-_W0QQcmdZViewItemQQhashZitem5641f77e95QQitemZ370473926293QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    There are several things you have to work out with these kits. 1 the axle flange has to be filed down to get the rotors to lay flat. 2 You may have to do a little work with your E brake setup. One thing to watch there is to leave enough slack in the cable/frame attaching points because they have to go to the back to remove the calipers. 3 same thing with the location of the weld on tabs for the hoses. leave enough freeplay for caliper removal. Probably missing something ,but I thought it was a pretty easy undertaking. It will add to a low brake pedal feel , so read up onM1's brake system findings, he covers everything that I can tell.
    Post by BILLS66 Fri Jan 14, 2011 6:00 pm
    Digz, Thanks for putting more crazy ideas in my head! If I was a little farther along on my van I would probably be doing the rear discs. Heres a couple of headliner pics getting close to done. Bill
    BILLS66   VAN - Page 4 002-18
    BILLS66   VAN - Page 4 001-16
    Post by Digz Fri Jan 14, 2011 6:07 pm
    Here's a site to help you sleep at night Bill..LOL More ideas.
    http://www.swego.com/store/pc/home.asp LED lighting
    Thats going to look nice !
    Post by BILLS66 Fri Jan 14, 2011 6:26 pm
    So many ideas I am so confused. heheheh I am going to grab a beer and think!
    Bill
    Number of posts : 1747
    Post by econopoor Fri Jan 14, 2011 7:07 pm
    Now back in the days of grabbin a beer and having a think, The thoughts that came up most offen was I think I'll have another beer! drunken
    Duane in Tennessee.
    Post by Digz Sat Jan 15, 2011 6:52 am
    Here isa better link for LED stuff. http://autolumination.com/fixtures.htm way better !
    Post by BILLS66 Sat Jan 15, 2011 2:48 pm
    1 more panel in and I just realized this arms over your head work hurts! Bill
    BILLS66   VAN - Page 4 001-17
    Post by Guest Sun Jan 16, 2011 6:53 am
    Yeah! You feel those muscles you never knew ya had!
    Post by BILLS66 Wed Jan 19, 2011 6:14 pm
    I will never do another headliner! ouch! Last panel is done . Bill
    BILLS66   VAN - Page 4 001-18
    Post by Digz Wed Jan 19, 2011 6:24 pm
    cheers cheers cheers I'm sure it hurts to much to do that. Looks good !!
    Post by BILLS66 Sat Feb 12, 2011 3:21 pm
    New bigger rear tires. Bill
    BILLS66   VAN - Page 4 003-11
    Post by DanTheVanMan Sat Feb 12, 2011 4:15 pm
    WOW! Very nice Bill...... cheers
    Post by BILLS66 Sat Feb 12, 2011 4:19 pm
    Thanks Dan, I also noticed a little axtra leg out on the highway!...... Bill
    Post by EconoCarl Sat Feb 12, 2011 4:26 pm
    Schaweet! Good lookin' van Bill.
    Post by BILLS66 Sun Feb 13, 2011 11:46 am
    Dog house lid I got from m1d is done now onto carpet and uhpolstering the dog house and the drivers area will be just about done. Bill
    BILLS66   VAN - Page 4 001-21
      Current date/time is Sat May 18, 2024 10:08 am
