Im a new owner of a 66 Econoline Super Van and I can't figure out if it has a 240 or a 170, I supose I could figure it out but I cant even find the VIN plate. The one on the driver's door frame is gone and I can't find the on the engine...please help.
engine ID help
Re: engine ID help
I'm guessing if it's a '66 super van it almost has to have the 240, unless it got replaced somewhere along the way (but why would someone go with a 170, unless they had it laying around?).
Re: engine ID help
Welcome hotrod524.nice van the vin number should be stamped on the dog house front floor area i believe,should also be stamped on one of the braces near the rear doors, corner braces.that wont tell you engine size unless you are sure it is a stock motor.
Re: engine ID help
Doesnt the 240 have a removeable intake? I know the 170 is made as part of the head and can't be unbolted/removed...
Re: engine ID help
It probably came with a 240 but it could be ordered with a 170 also. The intake as stated is removeable. The VIN plate on a 66 would be on the drivers door rear edge,not the door jamb itself. The VIN itself on a 65-67 model is easily seen on the floor hump top lip at the rear base of the doghouse. It can be seen with the doghouse still installed. 61-64 models have it stamped under the doghouse itself under the tar sealant. You may also find it on the rear inner brace by the tail lights but I ve seen several ones where I couldnt see it there. Sometimes its hidden by excessive layers of paint.
Re: engine ID help
Thanks alot everyone for the resposes. What a great Econoline family!!
