    1980's 250 swap in 65 G10
    Fairlane514
    Fairlane514
    Number of posts : 32
    Registration date : 2023-01-28
    1980's 250 swap in 65 G10 Empty 1980's 250 swap in 65 G10
    Post by Fairlane514 Sat Feb 11, 2023 5:52 pm
    The 230 in the van now is tired and sending smoke signals for help.
    Have access to a 1981 250 from a square body C10. My concern is the total width of the engine with the intake and carburetor. It may not fit in the doghouse, I only have a few measurements to judge by with pictures.
    Curious if anyone has done this swap. The intake is integrated into the cylinder head, so I cant just swap intakes.
    Thanks
    AzDon
    AzDon
    Number of posts : 714
    1980's 250 swap in 65 G10 Empty Re: 1980's 250 swap in 65 G10
    Post by AzDon Mon Feb 13, 2023 6:44 am
    I'm surprised that nobody has answered this yet....It's my understanding that a 230 head will go right on a 250, as folks have done this so they can use aftermarket manifolds....You might have to do some deep searches here and at VCVC.org to get more detailed info....
    I've always just swapped to v-8, but that creates fabrication requirements on a first-gen...
    Fairlane514
    Fairlane514
    Post by Fairlane514 Mon Feb 13, 2023 7:03 am
    Yeah, Im probably going to do a valve job on the 230 head and bolt it on to the 250. Intake, exhaust etc will then just go back in factory position.
    AzDon
    AzDon
    Post by AzDon Mon Feb 13, 2023 12:25 pm
    If you convert to HEI, be sure to run a new non-resistance wire between the key switch and the coil (HEI un it)..... All these vans were pre-HEI and had points distributors which had a resistance wire powering the coil....HEI uses full 12 volts.....
    Fairlane514
    Fairlane514
    Post by Fairlane514 Mon Feb 13, 2023 12:29 pm
    Yep, I plan on that as well.
    smittyG10
    smittyG10
    Number of posts : 16
    Registration date : 2018-10-25
    Post by smittyG10 Fri Jul 28, 2023 3:54 pm
    I put a 250 in my van , had to alter throttle linkage a bit but otherwise no other issues
    Fairlane514
    Fairlane514
    Post by Fairlane514 Fri Jul 28, 2023 4:16 pm
    Yes, overall not a bad swap. I used the 230 head, intake and exhaust. The throttle linkage went right back in.
    DanTheVanMan likes this post
    gfleduc
    gfleduc
    Number of posts : 349
    Post by gfleduc Sat Jul 29, 2023 1:52 pm
    Later 250 engine went into my '65 - no notable issues.
      Current date/time is Mon Oct 02, 2023 7:20 am
