67 Econo Van - Arlington, TX - $15000
Clutchburner- Number of posts : 6
Registration date : 2019-03-26
nice van but i dont facebook,any contact info ?
There's a phone number in the description...not sure if it's the seller's or the shop's. His name is Matthew McCrane.
Seller's Description
It’s time to let go of my ‘67. I’ve owned it for a year and have made it an every day driver. I just spent over $4500 in custom work at Murray Kustom Rods in Ft Worth.
325-642-5347
Custom Mount and Install of Vintage Air AC/Heat/Defrost
Vintage Air Dash Control
New Champion Radiator
New Spal Fan
New Steering Column Wiring (Turn Signal and Horn)
Custom Radiator Shroud and Mount
Carb Rebuild
Custom Throttle Cable Assembly and Mount
New Plugs, Wires, and Distributor
New Battery and wiring
Original seats recovered & new padding
Includes the original belly pan!
And More!
Only significant rust is on the bottom of driver side mirror mount.
Plenty of extra parts.
NEEDS:
It has original wiring throughout, might need to be replaced.
Missing washer bottle and tubes to wipers.
Paint job is older and dull, could use buffing.
Original shoe brakes and gas tank. Needs to be checked.
Missing the original roof liner and lights.
Dog house probably needs to be insulated.
Very limited body damage on passenger rear panel.
325-642-5347
New Spal Fan
Carb Rebuild
And More!
NEEDS:
