    dash gauge cluster
    gregb
    gregb
    Number of posts : 96
    Registration date : 2015-09-06
    dash gauge cluster Empty dash gauge cluster
    Post by gregb Mon Mar 16, 2020 11:49 am
    My speedo quit. confirmed its in the cluster.
    is there anyone out there that rebuilds or has a good one for sale ?cheers
    Number of posts : 2635
    dash gauge cluster Empty Re: dash gauge cluster
    Post by savage Mon Mar 16, 2020 3:06 pm
    I got a few, what all you looking for?? Your speedo just quit turning??
    gregb
    gregb
    Post by gregb Tue Mar 17, 2020 9:25 am
    Yes the speedo quit turning....
    is was a little noisy so I guess after55 years it said enough ! lol
    gregb
    gregb
    Post by gregb Mon Sep 28, 2020 1:16 pm
    please - need help on best way to remove the switches on gauge cluster.
    photos would be awesome.
    cheers
    Number of posts : 12254
    Post by donivan65 Mon Sep 28, 2020 10:00 pm
    ,,,,,at least its not about a sway bar,,,,,
    They all got bezels that hold the switches in,,,you got to remove the knobs and cylinder to get to them,,,,the wiper should have a set screw on the bottom of the knob
    You put the key in and try to turn it LEFT while poking a wire in that little hole to remove the cylinder
    dash gauge cluster Dscn0041
    dash gauge cluster Dscn0043
    You could wear out your finger pressing hard on the spring button on the back of the headlight switch while jiggling on the knob to pull it out,,,you might have to put some WD40 on the shaft and button to loosen it up.....
    dash gauge cluster Dscn0044
    dash gauge cluster Dscn0042
    jrdunn96 and chiefcrewdog like this post
    gregb
    gregb
    Post by gregb Tue Sep 29, 2020 9:17 am
    thanks donivan !!
    do you know of a tool to remove the bezels ?
    i did find on corvair america they actually have the guaged cluster frame chromed !!
    i hope you are stayin save from the fires - its terrible !!
    praying for rain for you guys.
    in vancouver we had the smoke so bad it was like we were in a cloud for 2 weeks so i can only imagine.
    Post by donivan65 Tue Sep 29, 2020 10:20 am
    They might not be on too tight,,,,you can try to wiggle the switch while twisting the bezel with your hand to undo them,,,,,or put a piece of tape on the end of a paint scraper or screwdriver and tap the bezels to undo them if you dont want to scratch them,,,,,
    Number of posts : 890
    Post by jrinaman Tue Sep 29, 2020 11:07 am
    while it is apart, good time to clean up your clear plastic. wet sand and buff, it will be like new.
    gregb
    gregb
    Post by gregb Tue Sep 29, 2020 11:19 am
    thanks guys - yes the trick will be to not damage the bezels.
    right now they are mint
      Current date/time is Fri Jan 24, 2025 12:23 pm
