I am putting in pop out windows in the rear two doors that originally had fixed windows.
I have gasket material for pop out windows that I bought on eBay. They are a length of gasket material that you cut to length and press over the rib in the door's window open area. At some point the two ends butt up against each other.
My question is did the factory use this style or was it one molded piece? if it was one piece that the ends butt up to each other, where the ends meet should this be at the top middle or the bottom middle of the window frame? or somewhere else?
Also where the two ends meet should there be some kind of sealer used to join the two ends or do you just have them touch without anything joining them?
Any tip on making a clean cut of this material would be appreciated.
Thanks... Keith
Thanks... Keith
