    LED Tail light
    Number of posts : 405
    LED Tail light Empty LED Tail light
    Post by Keith D Sat Oct 26, 2019 8:43 pm
    Any one running a LED rear tail light  / turn signal?
    Not a LED bulb in the stock housing but a aftermarket housing / lens with multiple LEDs built in.
    If so what company / part number are you using that fits into the stock opening? Any modifications that were done to make it fit? Also I prefer chrome not a black trim ring.
    Pictures if you got em.
    Thanks...Keith
    Number of posts : 8770
    LED Tail light Empty Re: LED Tail light
    Post by dix Sat Oct 26, 2019 9:00 pm
    yeah i'm running them , Napa auto parts / grote lights 4 "round with the rubber ,
    you will have to trim the inside flange , never to be seen then the stainless steel trim rings ,
    you just screw it into the rubber
    Post by dix Sat Oct 26, 2019 9:02 pm
    LED Tail light A100-310
    Post by Keith D Sat Oct 26, 2019 9:24 pm
    Thanks Dix,
    They look good... Nice and bright I assume.
    Post by dix Sun Oct 27, 2019 2:15 pm
    LED Tail light A100_t10
    LED Tail light A100_t11
    Post by Keith D Sun Oct 27, 2019 2:49 pm
    Yep they are bright.
    I found these while cruising the Grote website, I eliminated my backup lights so these will be perfect.
    https://www.grote.com/products/55202-4-inch-round-led-stop-tail-turn-with-back-up-stainless-steel-flange/
    sweetvan
    sweetvan
    Number of posts : 251
    Registration date : 2013-12-16
    Post by sweetvan Tue Oct 29, 2019 8:36 am
    I like the integrated lens with the back-up lights. Very functional and they look great. Good web site too.
    caleboh
    caleboh
    Number of posts : 48
    Registration date : 2017-12-25
    Post by caleboh Mon Dec 16, 2019 12:28 am
    Very nice. Are they plug and play?
    Post by Keith D Mon Dec 16, 2019 1:23 pm
    caleboh wrote:Very nice. Are they plug and play?
    No...You need to buy a special wiring adapter then splice in to the wiring harness.
    Post by Keith D Sat Dec 28, 2019 12:58 pm
    Here is what they look like on the van.
    LED Tail light Img_5110
    dix and vantra like this post
    Post by dix Sun Dec 29, 2019 3:10 am
    nice choice
    docmcg
    docmcg
    Number of posts : 206
    Registration date : 2014-09-08
    Post by docmcg Wed Jun 30, 2021 4:36 pm
    LED Tail light 88c9d010
    Found these at a local truck shop. Brand name is Trux Accessories. Item number is TLED-419RF. Damn near perfect fit. May have to adjust mounting hole location. 19 leds, very bright.
    dix and sweetvan like this post
    docmcg
    docmcg
    Post by docmcg Wed Jun 30, 2021 4:40 pm
    LED Tail light 9be4b710
    I also have a pair of these. Quite a bit of alteration to get them to fit inside the body opening. Had to enlarge the hole on the truck, and grind down the diameter of the stainless steel trim on the light. Can’t make up my mind which way to go. Opinions needed and welcomed!
    dRomer48 likes this post
    Post by dix Thu Jul 01, 2021 12:24 pm
    on your truck i see you don't have the reverse lights so I'd use the 2nd set,
    i might have a smaller trim ring to use
    Post by dix Thu Jul 01, 2021 12:26 pm
    docmcg
    docmcg
    Post by docmcg Thu Jul 01, 2021 4:10 pm
    Appreciate that Dix. I’m a ways off from actually installing the lights. I can make either set work, just haven’t made up my mind!
    dRomer48
    dRomer48
    Number of posts : 36
    Registration date : 2018-10-01
    Post by dRomer48 Wed Sep 01, 2021 7:41 pm
    docmcg wrote:LED Tail light 9be4b710
    How bright is the reverse light? My uncle might like that for his new truck project. Gonna show this to him when the truck return from wheels and tires installation plus alignment.
    docmcg
    docmcg
    Post by docmcg Wed Sep 01, 2021 7:54 pm
    You will know when it’s on! Being a led, it’s quite bright.
    gmytych and dRomer48 like this post
      Current date/time is Tue Nov 26, 2024 11:49 am
