Hi All
The weather is looking better now so I'm trying to get as much done to the van as I can before it's pressed into service.
I'm doing a colour change from basecoat red metallic (no clearcoat!) back to almost original light blue. The last respray looks like it was done in a lunch break - nothing removed and some 'creative' masking.
I'm taking the doors off to sort sagging hinges and will paint them off the van but I can't work out how to remove the exterior door handle on the rear door (1969 Gen2) - I can feel ends of one of the bolts and its nut on the inside and I can see the partially exposed screw heads on the outside - is there a way to remove the handle lever to get to the screw heads?
Thanks
Thanks
