Is it at all possible to install the glass run channels and beltline fuzzys without removing the vent window assy? I'm trying to avoid removing he vent assy.
beltline seals and glass run channel install
I have not been able to do it without removing the vent window.
I have not gotten into it yet. What makes it so hard to do, and requires pulling the vent window ?
I find it too tight to accomplish the belt line fuzzies without at least removing the window. I took everything out and did the vent window rubbers at the same time.
69- Number of posts : 434
Removing the vent window assy is not that hard - except finding the screw inbetween the old rubber. Other than that - rather easy.
(unfortunatly, I skipped replacing the vent rubber; should have done that at the same time...)
