So if you didnt know there are companies that make aftermarket electric power steering columns.
They arent cheap, some require cutting, and personally I wouldnt trust set screws to keep me from going off the road. That said, most seem based on a DIY solution based on some small import cars power steering units.
In this 4 part video series the author discusses different units but specifically the Prius units that even without a computer module still work well.
With a similar amount of metal work and some spline adapters or grinding to make a double D flat I think this would be a great option for any of the 60s van that use a steering wheel support with an exposed shaft. With some nice fab work and careful cutting and painting I will be most people wouldnt even notice.
FYI the Prius is about 3000lbs if you were worried about whether the motor could handle it.
More info
https://ls1tech.com/forums/suspension-brakes/1848775-35-electric-power-steering-fail-safe-no-ebay-module-no-caster-issues.html#post19425307
Hope this helps!
Feel free to post any steering spline specs for your model
More info
Hope this helps!
