by jrdunn96 Sun Apr 16, 2017 5:31 am
Ok, I'll spill what little I know. I'm currently running four Lincoln Town Car wheels (Got a heck of a deal on them and they don't look half bad.) 15"X6.5". The reason I didn't post was I couldn't remember the tire size and I keep forgetting to check. I believe they are 215/60-15. They are great all around except the drivers' front rubs the drag link at full right lock. That's not too big of an issue since these things have a small turning radius, you can just adjust the stop screw. With my current suspension and of sag of it, I couldn't run a wider tire up front. I could, however run a wider one out back. I have a local tire shop that will let me "buy/borrow" used tires so when I get to that point, I can experiment. My stock "steelies" won't run on most disc brakes because of the weld flange. The discs they would run on would be small. That's it, what little I know. If you're patient, someone with more knowledge will chime in. Don't give up on us yet!
Here is a pic of it with 16" white wagon wheels(off my hay buggy).
Last edited by jrdunn96 on Sun Apr 16, 2017 2:01 pm; edited 1 time in total (Reason for editing : Grammar)
