Great pics jrinaman. I finally got mine done. I did just about the same thing you did and it worked out great. I thought about using steel spacers AzDon but I went with 1 thick washer and 1 lock washer. Now the leaf spring bolt/pin is going thru the shim and into the axle hole like it should.
