Has anyone looked at these at a local parts place? I'm going to upgrade to the dual master and found that the power master is quite a bit cheaper than the manual one. If you look at the specs they give, both have the same bore and fitting sizes. Is there different valving inside or something to that affect that sets these apart.
Thanks in advance, Nick
