However, I got a rebuilt carb, and put it on there, and it did clear up some of the idle problems but it created a new one: now I'm getting a really bad bog when quickly going from zero to WOT.
If I go slowly, it revs up no problem and sounds great. If I go quickly, it makes a bad noise, tries to stall, then surges up hard.
I think it's leaning out. It's got a new fuel pump and I'll replace the filter and check the fuel line, but it started doing this with the rebuilt carb. It's a 2-bbl stock style. Any help on what to adjust would be awesome. Timing should be good as well. Boo!
