I'm putting my E-pup back together after taking everything apart and I working on the fuel system. My dumb question is---on the fuel pump with the filter canister on top, which port is input(from tank) and output(to carb). I cant remember and I having difficulty getting the pump to send fuel to the carb. Everything is new--tank, sending unit, pump, carb,lines,etc. I've always thought that the lowest port on a fuel pump goes to the tank. I'm not sure this is the case on these pumps with the filter canister on top. One port is threaded, the low port, which I thought went to the carb---so this contradicts my thinking. I could have a bad new pump----it wouldn't surprise me. I'm starting to see a very high failure rate on all these junk Chinese parts from these parts houses. I've already experienced a junk dizzy, junk rotor, junk fuel sending unit, junk control module, just to name a few on this build. These Chinese parts have almost reached a point where they are not even usable. I'm chasing problems that shouldn't exist.
THX Mike
THX Mike
