HurricaneBilly
    please help .
    HurricaneBilly
    HurricaneBilly
    Number of posts : 25
    Registration date : 2014-11-25
    please help .  Empty please help .
    Post by HurricaneBilly Tue Jul 07, 2015 12:19 pm
    Okay guys , its been a while and now I am back .
    Today after riding van for a short trip . I got back in her and she won't start . all electronics work fine but as I turn the key to the start position . nothing , not even a click .
    So I am thinking I will need a new switch . after doing a search for the switch . I came up with nothing . well almost nothing . I can only find the inside part ( one with keys ) but I would like to replace the whole thing . and even the but .
    If you know where to get this part for a 65 g10 . I would be grateful.
    Number of posts : 12246
    please help .  Empty Re: please help .
    Post by donivan65 Tue Jul 07, 2015 12:58 pm
    When the van gets hot its pretty common for the starter to not operate,,,,,,,,,because of the wiring,,,,,,,check that connector next to the carburetor to see that it is tight,,,,,,,take a screwdriver and short across the battery and S terminals on the starter solenoid to bypass the wiring and see if the starter cranks,,,,,,,
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Tue Jul 07, 2015 2:30 pm
    get a 12volt test light and check and make sure you're getting power to the switch. If that checks out then check and make sure the purple wire is sending power to the starter when you twist the key.
    Post by Twinpilot001 Tue Jul 07, 2015 2:51 pm
    Get over to = Rockauto.com   look up switch  ignition for a 1967 g10 van they have them  for 7-20 bux. dont know if 67 is same  as urs yet ?? maybe?
    I bought my last one a year back from napa.
    Number of posts : 672
    Post by samsvan Tue Jul 07, 2015 3:29 pm
    No1rascal
    No1rascal
    Number of posts : 306
    Registration date : 2013-02-19
    Post by No1rascal Tue Jul 07, 2015 8:31 pm
    check the connector inside the doghouse
    HurricaneBilly
    HurricaneBilly
    Post by HurricaneBilly Tue Jul 07, 2015 9:55 pm
    Thanks guys .
    Post by Twinpilot001 Wed Jul 08, 2015 8:10 am
      Current date/time is Fri Nov 22, 2024 8:14 am
