I'm looking for an axle for my '66 and was wondering what years would fit.
I might be able to get a '63.
Thanks
econorat wrote:Thanks guys,
I'd like to have the front low and the rear up, sort of the "California rake"
Cheers!
fmc56 wrote:The axles are the same but the spindles changed in 64 and they use different kingpins. As long as you get the kingpins for the axle you are using you should have no problems. I have a 65 axle in my 63, It came in a parts truck with new kingpins already installed.
Fred
econorat wrote:Oh well, the tubular drop axle doesn't have any spring perches or shock mounts. Would have to weld these on.
The 1964 axle is slightly bent and when I inserted my old pins just for test fitting I noticed they wiggle a little. How much play is there supposed to be?
Can the axle be straightened out by a shop?
donivan65 wrote:And tight would mean a maximum of .003 between the kingpin size and it's bushing.
econorat wrote:Machine shop said the axle has to be heated and the bore hammered to smaller size than re reamed to king pin size.
Cost estimate: $750
Cheers to that!
