So when you grab the rod that operates the plate when you hold the gas pedal down, can you make the plate open all the way,,,,,,,there looks to be 2 places to adjust the rods,,,,,,and it looks like you need to unscrew the connectors further out on the threads,,,,,,check that pivot bracket bolted to the back of the doghouse,,,,,,see if anything seems loose or sloppy,,,,,,,,you got 3 rods,,,,the gas pedal pushes the bottom rod,,,,,which pushes the middle rod, which pulls down on the top rod that operates the carburetor,,,,,,and how about the gas pedal,,,,,,,is the pedal on the shaft tight,,,,,,,are the bushings on the shaft worn out,,,,,,,is the bracket that holds the pedal to the floor loose?
