No,,, that turned out to not be quite accurate,,,,,, It is true that a single belt will stretch and work harder according to the load applied,,,,,,,,,,,,,HOWEVER you can get a single belt to grab as long as you have enough wrap on the belt as well as belt and pulley thickness of the belt, which translates to CONTACT AREA, HOWEVER remember that you are also putting a MUCH HIGHER LOAD onto one belt and the same idea as dual tires splitting the load versus a single wheel load.
I have never liked dual belts, and the so called MATCHED SETS that are sold and much prefer the idea of a single belt HOWEVER using a SERPENTINE TYPE as there are no issues with one belt stretching more than the other, etc, etc,,,,, The SERPENTINE belt was designed to offer more strength and get rid of that issue,,,,
HOWEVER,, pay attention::::::::: On a small block Ford there are TWO circulation timing covers that can be used and they need to match the water pump. In my conversions I use the SHORT NOSED MOTORSPORTS ,,,,,,,,,,,,,,STANDARD ROTATION water pump and matching STANDARD ROTATION timing cover,,, THEY NEED TO MATCH!!
ALSO,,,,if a water pump is driven by the non grooved side of a SERPENTINE belt that means it is a REVERSE DIRECTION WATER PUMP AND MATCHING TIMING COVER,, if the water pump is driven by the GROOVED SIDE of a Serpentine belt that means it is the STANDARD ROTATION timing cover and matching pump...
Dual pulleys directly replace the single pulley if you want to go dual belts,,
On a recent build,,, Early three bolt dampener and LACK OF SERPENTINE pulleys for that early of an engine with a three bolt dampener. EASY Solution was to replace the stock dampener with an after market high performance unit that accepted either a three bolt pulley or a four bolt pulley,,, TOO EASY and now more selection of pulleys from people like Summit, Jegs, March, Billet Specialties, etc, etc, etc, etc, etc,,,
vic,,,,,,,,,,,,,,,,,,,,, late for work again,,,,,,,sorry if short
