Hi Guys,
Within the last 3 months I've replaced the following brake parts. Master Cylinder, Front wheel cylinders, front drums and shoes. After this I hired a mobile mechanic to help me bleed them. I didn't pre bleed the MC before R&R(didn't know). First they were super soft, then very very firm.
I noticed driving to work short drive, that by the end of the drive it seemed like the front right would be slightly rubbing to the point of a small squeak. Also felt a little resistance like the brakes were engaged. Didn't feel this for the first 3\4 of the drive. I thought no big deal must be the adjuster is a bit too tight and I needed to back it off. I got lazy and didn't do that.
I was driving last night and it was a bit longer than the normal work drive. I felt more and more braking build up. It then stopped me at a light and i couldnt move. I tried yanking the ebrake a few times, putting it in reverse and driving no go. I only produced burn outs. I had to get towed. When I got home the brakes had let up some and it was rollable again. I'm going to take the truck to a professional. I wanted to get some ideas of what it might be.
Maybe the new MC isn't good? Air left in the lines? Water contamination in the fluid?
Thanks for your knowledge and assistance.
