on the dodge A series vans. if you have correctly adjusted the cross shaft, but you are still having "up down wiggle". on the bottom of the gear is a square plate with shims. you can sometimes remove the shims to eliminate the play. do this carefully, and with the pitman arm removed ,you don't want any bind at all.
steering gear adjustment addendium
dodge A-108- Number of posts : 67
