by donivan65 Tue Mar 24, 2009 11:49 pm
The brake light switch sends a signal to the turn signal switch and the turn signal switch determines which brake light, or lights come on,,,,,there are contacts in the switch that do this, you can see them if you pull the steering wheel off. They look like big staples,,, you might be able to clean them,,,,You don't have a hazard flasher switch on there, do you????,
