    Speedo Cable?
    BlueSteel
    BlueSteel
    Number of posts : 111
    Registration date : 2013-05-15
    Speedo Cable?  Empty Speedo Cable?
    Post by BlueSteel Tue Aug 26, 2014 2:12 pm
    My speedo cable crapped out on me several months ago... so I've been getting infinity miles/gallon lol.
    Anyways I got a new speedo cable from NAPA.  i traced the cable back to this... I see a small hex head... do I just loosen the hex and pull the cable from the trans and insert the new one in and run it up... or am I skipping important steps?
    Speedo Cable?  0826140908
    Carl
    Number of posts : 142
    Speedo Cable?  Empty Speedo cable
    Post by Carl Tue Aug 26, 2014 6:43 pm
    -that worked for me, but I used a good used cable instead of a new one
    BlueSteel
    BlueSteel
    Speedo Cable?  Empty Re: Speedo Cable?
    Post by BlueSteel Wed Aug 27, 2014 8:39 pm
    I accidentally placed this in campers... can the Mods moved this to E-discussion forum? Sorry Sad
    Number of posts : 2011
    Post by Barnabas Wed Nov 26, 2014 7:17 pm
    Are you sure it is a bad cable? Small plastic gear at the transmission may be bad.
    If the speedo needle jumps around, you might just need to lubricate the cable. Pull the center cable out, grease it, then slip it back in.
      Current date/time is Tue Oct 03, 2023 10:42 am
