    Heater core leaking
    dulcimerbob
    dulcimerbob
    Number of posts : 115
    Heater core leaking Empty Heater core leaking
    Post by dulcimerbob Fri Aug 08, 2014 2:31 pm
    Can someone tell me how to bypass the heater core on my 65 with 240/6 ? Leaking and not ready to replace. Thanks
    DB
    Heater core leaking Empty Re: Heater core leaking
    Post by Twinpilot001 Fri Aug 08, 2014 3:33 pm
    should have an inlet & outlet hose to core - loop one end to other side of engine so water just circulates in a circle & not thru core!! By the way - try some bar's leak stop-pint liquid can- put it in & run it a while- likely will stop the core leak!! Ive done that several times - & had last now for over 8+ years now in 1 of mt late model cars.
    Number of posts : 12248
    Post by donivan65 Fri Aug 08, 2014 4:26 pm
    Hook them together under the glove box,,,,in front of the radiator or at the engine,,,,,,or plug them off.......
    Heater core leaking Ford_s11
    Heater core leaking Ford_s12
    Heater core leaking Steve_10
    Heater core leaking Steve_11
    dulcimerbob
    dulcimerbob
    Post by dulcimerbob Fri Aug 08, 2014 5:08 pm
    Thanks for the replies and the pics ! cheers cheers
      Current date/time is Tue Nov 26, 2024 3:07 pm
