+7
Donn
Yesterday1
66ThunderVan
11 posters
    Air Scoop or Air Dam
    Number of posts : 864
    Air Scoop or Air Dam Empty Air Scoop or Air Dam
    Post by Casimier Tue Jun 03, 2014 7:12 am
    Anyone ever put an air dam or scoop under their van to aid air flow to the radiator?
    Anyone have any pictures?
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Air Scoop or Air Dam Empty Re: Air Scoop or Air Dam
    Post by 66ThunderVan Tue Jun 03, 2014 1:49 pm
    I just dropped the front of the stock pan down about 4 or 5 inches to form a scoop.
    Number of posts : 1412
    Post by Vantasia Tue Jun 03, 2014 5:17 pm
    I was wondering this too for a Chevy? would it improve the performance of the louvers? I just ordered a pusher fan for mine now that I'm finding out it runs a little warm in the hotter weather...it would be easy make a sheet metal bottom scoop or use some sort of a hood scoop??
    Post by Casimier Wed Jun 04, 2014 5:33 am
    All that is needed is a little 12" wide wind baffle to direct the air up to the front of the radiator.
    Thunder you have a great idea about taking the pan and extending the front down about 3 to 4".
    So everyone knows, the bottom pan is a reverse scoop.
    Any other ideas?
    Yesterday1
    Yesterday1
    Number of posts : 3
    Registration date : 2014-06-02
    Post by Yesterday1 Wed Jun 04, 2014 10:37 am
    I have a scoop on my 1967 A100 that my Grandpa made. I will get pictures up in a few hours.
    Number of posts : 2016
    Post by Barnabas Wed Jun 04, 2014 3:35 pm
    I think the big problem is when stopped or driving slow when an air scoop would not help. The key is to get the hot air away from the engine and keep it from being sucked into the radiator.
    Post by Vantasia Wed Jun 04, 2014 7:19 pm
    I'm installing a 16" Flex-a-lite pusher van this weekend I just got from Summit Racing!
    Post by Casimier Thu Jun 05, 2014 5:25 am
    The engine starts to run hot at 60 to 65 mph.
    Soon as I slow down to 50 / 55 mph she cools off.
    I'm thinking that at speeds over 60 mph that the radiator fan does not get enough air
    to suck thru the radiator.
    That's why I'm thinking of an air scoop.
    Gotta remember I'm running a 2 spd Taurus fan & shroud with a good tested 140 amp alternator. Flushed coolant system 50/50.
    Post by Digz Thu Jun 05, 2014 6:09 am
    If it stays cool at the low speeds the fan is doing it's job. High speed you are up against air damming. Either from the doghouse or possibly the fan and shroud . a free flow of air should let it run cool enough without a fan at higher speeds.
    Donn
    Donn
    Number of posts : 692
    Post by Donn Thu Jun 05, 2014 6:22 am
    Jim,
    You running a V8 ? Sounds like it to me.
    Post by Casimier Thu Jun 05, 2014 11:33 am
    Hey Digz...that's my point, I don't think I have a free flow of air.
    That' why I'm thinking a scoop.
    And Donn, yes I'm running my new 289 V8...what a difference.
    Donn
    Donn
    Post by Donn Thu Jun 05, 2014 12:01 pm
    Big difference. The dog house set up was not made for a V8's heat. Not enough room for the air to exit. I cut a hole in the wall directly behind the engine and installed a puller fan to help clear out the hot air. Also have another fan in front of the radiator. I had to get rid of the thermostat and replaced it with a metal donut type piece that racers use. It is basically a big washer with a hole in the center that allows the water to flow better. There is some argument if these work or not but it worked for me. I'm running at 180 now.
    Post by Casimier Thu Jun 05, 2014 12:16 pm
    Donn
    Yes, I'm running a 289
    can you find out about the washer thermostat..part # etc.
    Here is what I found on the internet...for a pic
    Air Scoop or Air Dam Front_11
    FCC
    FCC
    Number of posts : 295
    Post by FCC Thu Jun 05, 2014 12:51 pm
    I think that someone pointed out that you may have an air FLOW issue at speed, not an air volume issue.  A scoop would add more volume, and if you indeed have a flow issue, volume will make no change to the temp, because its just getting backed up, so to speak.
    If you have a closed fan shroud, this may be effing up your flow at higher speeds.  Take off the shroud and test out the theory on the highway. But also watch it in traffic.. it may cause the reverse problem.
    Post by Casimier Thu Jun 05, 2014 1:20 pm
    Hey FCC
    You might be right about the backed up air problem.
    Maybe that is why FORD made the belly pan as a down force foil to suck air out of the doghouse.
    Still nobody with a scoop?
    FCC
    FCC
    Post by FCC Thu Jun 05, 2014 2:13 pm
    I thought the belly pan is a scoop, via the grill. It directs air to the rad, doesn't it?  Dropping the front down, as mentioned above, will scoop a higher volume of air.
    For a real sporty build, an air dam with a center knock out as an air path for an add on a coup would be cool.
    Number of posts : 8769
    Post by dix Sun Jun 08, 2014 2:25 am
    Air Scoop or Air Dam 100_1610
    Dodger 359
    Dodger 359
    Number of posts : 94
    Post by Dodger 359 Sun Jun 08, 2014 4:49 am
    What is the condition of your radiator?  Mine was heating up at highway speeds and fine around town.  It ended up being a water flow issue with the old radiator. Tried air ram on belly pan to see if it was air flow issue but didn't help.  Dropped in an FSR and good to go. I am running a 180 stat and installed a more accurate temp gauge as well.  I run 190 at idle and she drops to 160 at cruising speed.
    Post by dix Sun Jun 08, 2014 7:19 am
    A larger or smaller pulley on the water pump can increase or decrease the water flow.!!!
    Number of posts : 394
    Post by dan nachel Sun Jun 08, 2014 5:30 pm
    I was having the same heat problem at speed. When I swapped to the 302, I widened the dog box to get more flow around the engine, no help. I have a new 3 row radiator. I found a jeep radiator that is 16"x35". I mounted it at an angle below the front roll pan and plumbed it from the main rad to the second rad and back to the engine. The second rad is in place of the belly pan. It came with two fans on it, but I havent hooked them up yet. With a taurus 2 speed fan on the main rad, running on high, the truck now stays at about 180-185 all the time even with outside temps in the 90"s
    Post by dix Sun Jun 08, 2014 6:06 pm
    that rad/ fan system is known to be one of the best , and i'm thinkig with the fans running correctly on the top rad you can remove the lower one at the belly pan . But a old saying if it aint broke don't fix it aplys
      Current date/time is Sun Nov 17, 2024 5:44 am
