At this point I suspect These are from a 60's Chevy/GMC Van Can someone conferm for me ?
Can you ID this hub ? It was under a 56 GMC PICKUP entire axle was removed The Axle was bent, after having a machine shop replace the kingpins and bushings in a replacement axle I found (from a 55 Chevy 1/2 ton) threw it under the truck connected the drag an steering arms that were on it. Thinking to have it aligned later. 6 years
later now and decided to finish it, I discover the spindles, hubs, and steering will not work on my 56. Apparently they bored the spindles to fit
the 56 axle, didn't tell me that? bump stop does not line up nor the steering links? I wish I had not junked the bent axle, I need to find out what it came off of? It's looking like it may be easier to replace what ever axle it was rather than try to find good 49-54 Chevy hubs 5 X 4 3/4 pattern. If and when you reply I can send pictures to help! Would a great help Thanks
http://www.dropshots.com/tomb23
