    Help with Ford 200 Engine code
    zach_1950
    zach_1950
    Number of posts : 30
    Registration date : 2013-12-16
    Help with Ford 200 Engine code Empty Help with Ford 200 Engine code
    Post by zach_1950 Tue Apr 22, 2014 4:00 pm
    There is a ford 200 for sale and I don't know if it is the seven bearing block. It has the 5 freeze plugs but the stamp on the block is C6DE 6015-B
    Any ideas? Also will the transmission bolted to my 144 bolt right up to this block? It is the "crash box" transmission.
    zach_1950
    zach_1950
    Help with Ford 200 Engine code Empty Re: Help with Ford 200 Engine code
    Post by zach_1950 Tue Apr 22, 2014 4:01 pm
    And the 200 came out of a 66 mustang.
    Number of posts : 1747
    Post by econopoor Tue Apr 22, 2014 6:13 pm
    If it has five freeze plugs it's a seven main block. That's what the freeze plugs holes are for. To clean out the sand between the main webs. 65 blocks just had the small bolt pattern. 66 should have both bolt patterns. The 144 bell uses the small pattern so it will work with either block. The 200 likes the bigger clutch but it will work with the small clutch. You should be good to go.
    Duane in Tennessee.
    zach_1950
    zach_1950
    Post by zach_1950 Tue Apr 22, 2014 6:18 pm
    Thanks for the help that's exactly what I wanted to hear Smile
      Current date/time is Sun Nov 17, 2024 2:13 pm
