    Thrush outsiders side pipes
    playnpossum
    playnpossum
    Number of posts : 115
    Registration date : 2014-02-17
    Thrush outsiders side pipes Empty Thrush outsiders side pipes
    Post by playnpossum Sat Apr 19, 2014 1:40 pm
    Any members here running side pipes? I have a set of these thrush outsiders that I want to install on my van, I have a 318 with stock manifolds. Does anyone have a picture or can tell me how they've routed the pipe from the manifold to the side pipes.
    Number of posts : 957
    Thrush outsiders side pipes Empty Re: Thrush outsiders side pipes
    Post by slowflapper Sun Apr 20, 2014 5:24 am
    Mine are currently hard piped to the stock manifolds. I think it probably causes a little bit of vibration roaring down the road but cant swear to it. When I rework the engine Ill look into the stainless steel flex connectors so there's a little wiggle room for the engine.
    just make sure you stay out of the front wheel well with the 90 or your front tires might scrub.
    playnpossum
    playnpossum
    Post by playnpossum Sun Apr 20, 2014 7:23 am
    Slowflapper how did you route the hard pipe? I'm thinking about the steel flex common on most car, but in mock up it looks like ill have to go between the leaf spring and frame.
    Post by slowflapper Tue Apr 22, 2014 9:50 am
    I think it goes underneath the spring but Ill check tonight and let you know
    Post by slowflapper Mon Apr 28, 2014 6:58 am
    ok, mine run underneath the springs.
    Thrush outsiders side pipes 20140426_185450
    Thrush outsiders side pipes 20140426_185500
      Current date/time is Wed Sep 18, 2024 11:38 pm
