FIZGIG
66mnecotruck
Stock antena?
66mnecotruck- Number of posts : 327
Registration date : 2014-02-15
Stock antena?
FIZGIG- Number of posts : 334
Re: Stock antena?
Doesn't look stock.
Re: Stock antena?
Dang:)
Re: Stock antena?
I could be wrong but the ones Ive seen are like mine and I will send you a pic later tonight if you want.
Re: Stock antena?
Thanks FIZGIG.
fmc56- Number of posts : 553
Re: Stock antena?
Not stock. Tough to find one new or used but they still make a close reproduction, fit VW's.
http://www.jbugs.com/product/58-3500.html
Buzzard- Number of posts : 90
Re: Stock antena?
NAPA has a good also, it comes with a spring on the bottom of it that can be removed. Mine did not come with a radio so i had to drill 2 holes on the pass side to install antenna, works good and looks pretty close to stock. They did not have it in stock so it took a extra day to get it, i think it was around $15.00 bucks
- Number of posts : 8731
Re: Stock antena?
the one fmc56 posted is also the same replacement the dodge gang uses,
Re: Stock antena?
Thanks guys, looks correct to me.
- Number of posts : 2011
Re: Stock antena?
Here is a link to the 1961 Antenna Accessory kit that the Ford dealers used to install the antenna at the dealership. It shows a good picture of the antenna. The last page can be cut out to use as a template for locating the holes.
http://econolineid.com/docs/Antenna_Accessory_Kit_IS.504.pdf
Re: Stock antena?
Re: Stock antena?
Holy cow that is close.
