    I looking for some one that can photo crop
    Number of posts : 8770
    I  looking for some one that can photo crop Empty I looking for some one that can photo crop
    Post by dix Sun Feb 23, 2014 9:53 am
    Thanks for any help in advance,  I'd like to take a stock a100 dodge grill and add a billet grill to the opening of the grill, but I'M not that far advanced with the computer,
    I  looking for some one that can photo crop Untitl12
    I  looking for some one that can photo crop Kgrhqy10
    Number of posts : 2036
    I  looking for some one that can photo crop Empty Re: I looking for some one that can photo crop
    Post by dodge man Sun Feb 23, 2014 9:55 am
    that would look awesome dix,,,
    Post by dix Sun Feb 23, 2014 10:00 am
    I've been wanting to do this, But i'd love to see it on the computer before i go get a donor grill.
    Post by dodge man Sun Feb 23, 2014 10:09 am
    SHOULD BE EASY TO DO, I KNOW WITH A COMPUTER YOU CAN SEE HOW IT WILL LOOK FIRST
    Post by dix Sun Feb 23, 2014 10:13 am
    Thats what i'm hoping someone can do for me...
    Number of posts : 2016
    Post by Barnabas Sun Feb 23, 2014 7:20 pm
    Something like this? I am assuming that the widths of the two images are similar.
    I  looking for some one that can photo crop Merged-Dodge-grill
    PS. This might be the first Dodge I have ever worked on.
    Post by dix Sun Feb 23, 2014 7:24 pm
    Thanks bamabas
    jfox
    jfox
    Number of posts : 111
    Post by jfox Sun Feb 23, 2014 7:38 pm
    your bumpers(rear) are very nice. Did you make them?
    I  looking for some one that can photo crop Empty bumbers
    Post by dix Mon Feb 24, 2014 3:29 am
    Thanks, And yes i did they are from a 66 mustang.
    http://www.ebay.com/itm/like/290547313648?lpid=82
    Number of posts : 1686
    Post by westcoastvanner Mon Feb 24, 2014 6:58 am
    How did you mount those Mustang bumpers, any close up photos?
    Post by dix Mon Feb 24, 2014 2:55 pm
    3/8 X 2" flat plate steel, leave it a little long,side the plate in where the bumber brackets came out of, C-clamp or vice grip them in place, Now the mustang bumperette has tabs on top and bottom .
    Becarefull bend the top tab to sit on the steel plate and also make sure you are lined up to drill the holes thru the plate where the old bracket bolted up. Then you can see the the plate will need cut on a angle , the top longer than the bottom,Make that cut, and adjust the the bend on the bumperette so it sits at the correct angle of the body, Now you will see the top of the steel plate needs to be wider weld a 2nd piece of 1/2 " plate to the 1st one then weld the bumperette to the top only , Then reinstall and drill out the 1/2 x 2" plate to bolt up in the old holes , just like the old bumper brackets over size both holes so you have a little up and down adjustment, BUT make sure the bumperette is sitting where you want it, on the top of the bumperette there is a small rubber bumper on them adjust them to sit about 3/16 from the body, welding the top only lets you adjust the angle of the bumperette to match the body line, then bend the lower tab under the truck and bolt it to the opposite side,THIS WAY I'M ABLE TO REMOVE THEM AND REINSTALL THE BUMPER IN ABOUT 1 HOUR, The police in pa can be a real pain if they want to, Also the front will work the same way. And last but not least DODGE MAN makes some real nice one from alluminum when he not taking a nap, ALL IN ALL THESE ARE NOT HARD TO DO, JUST TAKE YOUR TIME,
    Post by dodge man Mon Feb 24, 2014 3:11 pm
    I  looking for some one that can photo crop 97156710
    I  looking for some one that can photo crop 14566710
    after a long nap I whipped these up from aluminum plates
      Current date/time is Tue Nov 26, 2024 9:02 am
