by 66ThunderVan Thu Feb 20, 2014 6:47 am
This has been discussed before but, yes, others have installed AC in E100s. The van in my picture had a custom built AC back when nobody had any. I lived in Az., at the time, in 1976. I had an oversized doghouse , for the 351, and the compressor bracket was off of a LTD and used a York compressor, with valves that can be used to allow the compressor to vacuum the system. The condenser was mounted under the van between the frame rail and the outer body panel and had an electric fan on it. The fan could be turned off when the van was moving because of the air scoop mounted behind the front wheel well. Where there is a will there is a way.
