My new 67 Econo Falcon Wagon
- Number of posts : 8729
Re: My new 67 Econo Falcon Wagon
New truck looks real nice and the Daughter is all smiles as she looks for those keys..
Truck runs well, but the drip rails are a mess. Two owners ago did all of the work, but the drip rail repairs are failing and rusting. I don't thick they killed all of the underlying rust.
the ford gang will point you in the right direction, A knowageable bunch of them there
If you don't remove ALL of the old seam sealer and media blast ALL of the rust out, prep and reseal you WILL get rust through later. I've seen a lot of that. The only thing you can do, now is try to use a rust neutralizer of some form and spot treat the bad areas. But be careful not to get any on the good paint.
I have repair patches coming. Oh I'm going to remove all of the old seam sealer for sure.
Your paint looks pretty good. I hope you don't have to screw it up repairing the rust. If you do mess it up you could, just, repaint the white area and save some $$$.
I usually remove seam sealer before primer and paint by heating the bottom of the drip rail with a propane torch using just enough heat to loosen the sealer, prying it up with a screwdriver and pulling it out in a string. If you use this method be careful to keep the heat as low as needed or you can warp your metal.
Thank you great idea, might try a heat gun on low, and hope I don't warp the metal. Paint is great but the shop t.wo owners back did some bondo rust repair on the back right corner. Time to order a new corner. They put a new nose, gotta check that out as well
Heat on the drip rail is not a problem. It is 3 layers. Keep as much heat as possible on the outer part of the rail. The roof and side panels will warp if they get too hot. I doubt a heat gun will work well as it will spread the heat over a larger area. I use the torch, heating from below, working a 3 or 4 inch length, back and forth and pulling up on the sealer. As you apply heat the sealer will become surprisingly soft and usually will stay in one piece.
